Brother mfc 9130 cw with error message print unable 02
  • tonerjockey
    • Apr 2014
    • 553
    Hi Guys, I have run into the other Brothers, like the DCP 9045 CDN with the service 32, and the Brother MFP 9840 CDW with the "unable print 2A for the for sticking shutter.
    does anyone have any input on the cause of this error? and if its the belt solenoid shutter, where I might find it hiding please??
    thank you, Jim
  • tonerjockey
    • Apr 2014
    • 553
    Re: Brother mfc 9130 cw with error message print unable 02
    The info I received said that the main drive motor, harness our main board were suspect.I removed fuser and lubed bushings, removed cleaning unit to free it up a bit.pulled she cover svc motor didn't turn.I manually turn it and no binding felt reseated motor harness at main board.the motor isn't attached separately, so I suspect ours part of main drive unit.gonna sell customer a new same model so they can use existing supplies. Good customer. So, unless anyone has any suggestions, that is what I will do.
    Thank you, jim
      Thank you, jim
      did you make sure none of the supplies are binding?
      Print Unable 02
      Turn the power off and then back on again.
      Step Cause Remedy
      1 Main motor harness connection
      failure
      Check the main motor harness connection
      and reconnect it.
      2 Harness connection failure
      between the low-voltage power
      supply PCB and main PCB
      Check the harness connection between
      the low-voltage power supply PCB and
      main PCB, and reconnect it.
      3 Main motor failure Replace the process drive unit.
      4 Low-voltage power supply PCB
      failure
      Replace the low-voltage power supply
      PCB ASSY.
      5 Main PCB failure Replace the main PCB ASSY.
