Brother MFC L8650cdw
  • ChrisG
    • Oct 2013
    • 179
    Trying to locate the black duplex guide that sits outside the fuser assembly next to the rear door. We have the parts book but can't see it anywhere in the diagrams.
    Any help appreciated
    Chris
    TJL Copy
    • 22808
    Re: Brother MFC L8650cdw
    Chris
    TJL Copy
    I am an authorized tech... there is no L8650cdw
    are you sure you do not mean the L8850cdw?
    • ChrisG
      • Oct 2013
      • 179
      You are correct. It is the 8850
        • 22808
        ok..are you talking about the guide plate with the 4 rollers on it? LY7727001 FUSER COVER ASSY
        it's under 1. Frame diag #8
        • ChrisG
          • Oct 2013
          • 179
          Unless it comes with that piece, it looks as though it would sit on the outside of that guide between it and the door. But again I see no picture of it in the parts guide. We're hoping to be able to retrieve the old guide from the customer tomorrow to have something to compare it to.
            • 22808
            there are two plastic covers... left and right..covers power and sensor harness... that guide plate clips onto those covers.. not part of the fuser...clips into place above fuser in rear frame..
            did the customer lose it?
            look in service manual.. replacing the fuser... 2nd or 3rd step after "open back door"
            you have parts manny... what about service?
            • ChrisG
              • Oct 2013
              • 179
              Did not locate the full service manual, other than the individual pages you can hunt through on the service manual sites that want you to pay for a subscription. I glanced through those, but the entire manual would be helpful.
              Chris
              TJL Copy
                • 22808
                Chris
                TJL Copy
                send me your email...
                • ChrisG
                  • Oct 2013
                  • 179
                  chrisg@tjlcopy.com
                  Thanks again
                    • 22808
                    chrisg@tjlcopy.com
                    Thanks again
                    check your inbox
                    • ChrisG
                      • Oct 2013
                      • 179
                      check your inbox
                      In the service manual it shows on page 197 under step 1 of the fuser assy. removal, a back flapper holder that needs removed. I believe that to be the guide we are trying to locate a number for.
                      Chris
                      TJL Copy
                      • ChrisG
                        • Oct 2013
                        • 179
                        Just wondering if you had any thoughts on the aforementioned guide? Is there another series of this machine that might be similar to this who's parts manual might show that piece? Curiosity only really. The customer said for the most part it runs fine without it so long as they don't duplex then it tends to jam.
                        Thanks for all the help
                        Chris
                        TJL Copy
                          • 22808
                          Chris
                          TJL Copy
                          I had pointed out the guide... it IS NOT in the fuser IPB... but rather FRAME diagram look at #7 ( i believe )
                          • ChrisG
                            • Oct 2013
                            • 179
                            I apologize I thought I had replied to this already but obviously I didn't. #7 is the guide with the 4 little rollers in it. I've attached the picture from the book of the guide we were looking for.
                              • 22808
                              did a search in the PM of the back flapper mentioned in the SM... no such bird...
                              sat on hold with TS for 20mins until I got disconnected ( must have been their break time? )
                              will try again later.
