Re: Ricoh error code sc899
  • amelia112
    • Nov 2023
    • 1
    Printers are now the need of the hour for every individual. Among all the printer manufacturers, Ricoh is the top-notch printer manufacturer. Despite being the top printer, these printers sometimes develop a technical SC899-00 ricoh error and many people look for ways to fix this error. So, here in this article let us dwell into the solutions to fix the ricoh error SC899-00
    Guide to fix the error code
    It is important to update your Adobe Reader plugin or add-on to the latest version so that the chances of such errors get decrease to a fairly low level. If not taken care, this error will not allow the printer to perform its daily functioning. Also, you can transfer to some other web browser so that the error probability is minimized.
    Now if you are looking for a solution for fixing the Ricoh SC 899-00 error, you must go on reading further as proper steps have been included to alleviate this error easily:
    Step 1: Start the process of troubleshooting by detaching the printer networking cord.
    Step 2: Convert to the service mode by pressing the following keys in the sequence given: 0, clear, reset, 1, 7 and then keep the clear key pressed until the SP Menu is shown.
    Step 5: Later you will see that a verification message appears on the screen for which you will need to check the execute option so that you can proceed to the next step.
    Step 6: It is suggested to not select subsection 1 which states All clear key as using it will remove all the accounting codes from the Ricoh printer.
    Step 7: Now that the memory gets cleared, the Ricoh printer will get automatically switched off which will be a sign of saving all the changes that you have done.
    Step 8: Now you will see that the error message gets extinct when the printer is switched on for use and now, you can clear all the tasks from it that lead to such an error.
    These steps will enable you to get rid of the error and to operate the printer as it was before. Although this method is useful in answering how to fix Ricoh printer functional error SC899-00, if there is still an issue due to which the printer does not work like before, it is recommended that you consult a professional technician to solve the issue.
