MFC-L5900 CQ
  • deputydogg
    • Nov 2015
    • 172
    MFC-L5900 CQ
    When you scan or copy the image is light(not when printing or printing internal report). The machine is 2 years old with about 60k on it. It has gradually got like this, even with it on the darkest setting it is lighter than it should be. They also have 2 MFC-L5700's that were bought at the same time and one of them is doing the same thing.
    Any suggestions ?
    Thanks,
    Dave
  • Dickie
    • Nov 2011
    • 190
    Re: MFC-L5900 CQ
    I know it's stating the obvious but cleaning the optics would be a good place to start.
    Not au fait with american model numbers but if it does not have optics recalibrate the scanner.
    This is normally done by putting plain white paper on scan head and running maintenance mode 02 followed by 55 then 99 to exit
    Hope this helps
    • tsbservice
      Field tech
      • 7981
      Re: MFC-L5900 CQ
      Turn off toner save mode under Ecology. Also at 60k drum unit should be changed, they can only reset drum counter without changing parts.
      Agree optics would be always to consider especially if they smoke alot around machine or in dusty environment.
      • Dickie
        • Nov 2011
        • 190
        Re: MFC-L5900 CQ
        Sorry TSB it cannot be either of those as Scans are weak as well.
        Can only be optics or CCD logically
        • tsbservice
          Field tech
          • 7981
          Re: MFC-L5900 CQ
          Dickie, I like and truly appreciate your inputs. I admit we know theory and you're right on the money here. Still in my practice I never opened scanner of 6900 for cleaning and I have tons of them in the field.
          But, if Brother messed 5900 model scanner sealing...that would be another story.
          OP make 2 to 2 sided copy/scan from ADF, if 1 side output is bad and 2 good do what Dickie suggested.
          • deputydogg
            • Nov 2015
            • 172
            Re: MFC-L5900 CQ
            There are no optics to clean other than the scanner, it is clean. I tried the code 55 in maintenance mode with no change. When you do 2-2 thru ADF both sides are light. These machines are in a lawyers office which is clean and smoke free. Toner save mode is off.
            Is the CCD the only left that would be the culprit ? Is it cost effective to replace ?
            Thanks,
            Dave
            • tsbservice
              Field tech
              • 7981
              Re: MFC-L5900 CQ
              Do factory reset.
              • deputydogg
                • Nov 2015
                • 172
                Re: MFC-L5900 CQ
                Do factory reset.
                Is that done in the service mode ? If so whats the code ?
                • tsbservice
                  Field tech
                  • 7981
                  Re: MFC-L5900 CQ
                  Do it first from user menu:
                  Online User's Guide
                  • Dickie
                    • Nov 2011
                    • 190
                    Re: MFC-L5900 CQ
                    Yes reset is done via service mode
                    91 is a reset without changing any user saved information
                    01 Is a full reset but you will lose all customer set information so it would be a good idea to print out all available reports and settings before you do this. Then re print them afterwards and compare for any changes to reset parameters
                    Good luck
                    • deputydogg
                      • Nov 2015
                      • 172
                      Re: MFC-L5900 CQ
                      I've tried all suggestions with no change.
                      Thanks,
                      Dave
