BROTHER HL-L2360DW
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] BROTHER HL-L2360DW
    Hello all technician friends l have brother HL-L2360DW ...if l started this printer not function but this error code affiched there 0B ..Please help
    BEST TECHNICIAN . NICE PEOPLE .
  • tsbservice
    Field tech
    • 8017
    Re: BROTHER HL-L2360DW
    - Error code 0B01:
    An error occurred in the high-voltage power supply PCB ASSY while operating.
    - Error code 0B02:
    An error occurred in the high-voltage power supply PCB ASSY when the machine was in theready state.
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      - Error code 0B01:
      - Error code 0B02:
      My friend the error code l have is 0B ...l not seeing 01 or 02 ...so it's possibility to repaired this power supply?
        not likely ...
        the OB code is on the first screen... you have to look on next screen to see the 001/002
        don't you have a manual?
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          not likely ...
          nop....pm pls .
            nop....pm pls .
            sorry brother I don't have that manual... try posting your request here ---> https://www.copytechnet.com/forums/s...nual-requests/
            • zaza
              MECANOGRAPHE
              • Mar 2008
              • 1095
              by way thank you !
                by way thank you !
                no problem brother.. sorry I couldn't help out
