Firmware brother mfc-l6902
  • finhocamargo
    • Mar 2015
    • 23
    good afternoon can someone help me with the firmware of the brother MFC-L6902, which update through the front USB port, because I want to do a forced update thanks.
    Re: Firmware brother mfc-l6902
    what problem are you having?
    there is more software you need to do it.
    do you have the manual?
    • finhocamargo
      • Mar 2015
      • 23
      The equipment does not accept printing both from the PC and via the machine, it only copies. I have the other programs I just don't have the firmware
        what print driver are you using?
        does it have a WSD port? (WSD fucks everything up)
        • tsbservice
          Field tech
          • 8020
          Yes just connect MFP with USB cable to PC/laptop where Update tool is downloaded from Brother public site. Maybe you don't have access to internet?
          • finhocamargo
            • Mar 2015
            • 23
            she doesn't even accept that I print the report of a user of the machine itself
            • finhocamargo
              • Mar 2015
              • 23
              this does not work, already tried
              • tsbservice
                Field tech
                • 8020
                I have a plenty of these when NIC port on main board toasts. So you cannot print via network but then printing via USB cable always worked. Did you try USB cable?
                • finhocamargo
                  • Mar 2015
                  • 23
                  I have all the drives, I just don't have the firmware, I want to do a forced update before condemning the main board
                  • finhocamargo
                    • Mar 2015
                    • 23
                    the problem is that I need the complete machine, via USB I am very limited
                    • tsbservice
                      Field tech
                      • 8020
                      OK but why not try to update firmware via USB cable
                        it IS the preferred way
                        • finhocamargo
                          • Mar 2015
                          • 23
                          I'll try
                          • tsbservice
                            Field tech
                            • 8020
                            I have upgdated hundreds of Brother devices via USB, via network via USB thumb drive, via BRAdmin, You just name it
                            In fact I hardly remember last Brother MFP, printer or scanner which I touch and don't update it's so awesome easy to do that I do it always as a unpaid bonus for clients.
                            • tsbservice
                              Field tech
                              • 8020
                              I'll try
                              Just try.
                              Go to Brother site select model click on downloads, scroll to the very bottom, download file like BrMain4811, execute program it should find your device then agree to update, next, next, Done
