Brother printing Cyan problem
  • Drivee
    • Nov 2020
    • 322
    Hi
    anyone see this problem with MFC Brother?
    This is a pritner test so it is not a driver issue. OPC is new. Leterts are incompleate and something cut Cyan rows. Normal printing from Word will also show simillar problems.
    Re: Brother printing Cyan problem
    Originally posted by Drivee
    Hi
    what model is this?
    what is the life on the drums/dev units?
    is the laser/led clean?
    is the machine clean?
    Phil B. 'The Dentist '
    • Drivee
      • Nov 2020
      • 322
      what model is this? HL-L8260/8360
      what is the life on the drums/dev units? Araund 70%
      is the laser/led clean? No
      is the machine clean? Macine is clan.
      One more printout:
        One more printout:
        clean the laser/led assm
        genuine OEM toner?
        • tsbservice
          Field tech
          • 8020
          Change cyan with magenta or yellow toner to see if the problem moves from cyan to another drum. If it moves with cyan toner you know. If it stays then toner isn't problem.
          Make color registation and calibration.
          P.S.
          Also what look full CMYK color test pattern (Function code 71)?
          • Drivee
            • Nov 2020
            • 322
            Toner look like OEM but I never know as is easy to refill, I just get a picture of toner. I trying to solve problem from service, I think that I need to visit cite.
            It looks that laser/led is move to left or something. This dont look like toner problem. I think that he just need to run colour registation. If this do not help I will try today to change Cyan for Magenta or Yellow.
            Here is more tests.
