DCP-8410 Service Items
  • Crowfeather
    Printer firmware is !&$!
    • Mar 2021
    • 130
    Why is the LSU listed with a service life on the Brother kit?
    I find it absolutely bizzarre.
  • tsbservice
    Field tech
    • 8002
    Re: DCP-8410 Service Items
    Not if you are familiar with Brother devices. On some models they're considered as PM parts like fuser in example. You are not obligated to change laser unit though.
    • Crowfeather
      • Mar 2021
      • 130
      What I don't understand is the reasoning behind it.
      All of the traditional PM parts are those that wear/tear through friction (Rollers/Fuser/Belt)
      How does an oscilating light and some mirrors ever wear?
      • tsbservice
        Field tech
        • 8002
        I found dust in them depending on environment (keep in mind laser unit isn't sealed) mainly on poly mirror. Then when you replace the main board it's required to enter numbers from laser unit probably machine shifts some voltages depending on parts life, etc. What's the reason behind your interest, do you have to calculate PPC and cost of lasers breaks your deal or something else? I know they build the machine around laser sometimes but in the reality it's not such big problem for us.
