Brother HL-L6400dw - maintrance mode? wlan problem
  • galladr
    • Sep 2022
    • 9
    Hey,
    anyone could tell me how to enter maintrance mode in this Brother HL-L6400dw model? I want to try hard reset.
    Maybe someone have earlier firmware for this model? Now I have Ver. ZE (Jul 8 2022) but with this firmware WLAN module not working (don't have "WLAN" menu in Network and WLAN icon on home screen). Pasteboard - Uploaded Image
    Thanks.
  • CroceL
    Sharp / Brother Tech
    • Jun 2020
    • 62
    Re: Brother HL-L6400dw - maintrance mode? wlan problem
    Edit: Welp that picture is rather useless ^^
    1. Press & Hold "Home Button" while in ready state.
    2. Press & Hold the blank field at the bottom
    3. Enter Maintenance Mode with * 2 8 6 4
    4. MM 01 for Reset.
    • galladr
      • Sep 2022
      • 9
      Originally posted by CroceL
      [ATTACH=CONFIG]57142[/ATTACH]
      4. MM 01 for Reset.
      Thanks for reply!
      I know that this pic is useless, just show that I don't have that wifi icon.
      I did a hard reset, but still nothing. I check on 3 others Brother WLAN cards and still nothing. Probably mainboard issue. If someone have previous firmware I could confirm that.
      Thanks.
      • CroceL
        • Jun 2020
        • 62
        Originally posted by galladr
        Thanks for reply!
        Thanks.
        No no I meant my picture is useless not yours
        But sorry I have no way either to get an older firmware, I the printer still under Brothers 3-year warranty ?
        • galladr
          • Sep 2022
          • 9
          Nope. I just try to fix that wlan but it's nothing important. Thanks for your help
          • tsbservice
            Field tech
            • 8020
            You may want tell us what was done prior loosing WLAN
            Then we can help better.
            • galladr
              • Sep 2022
              • 9
              I wish to know that. We have a lot of printers various types (post-leasing). When I check this printer It didn't have WLAN. I check on 3 other WLAN card and still nothing. I try to update firmware, but this printer have latest one. That's why I wanted to upload some older ones to make sure it's damage to the motherboard.
              If it has to be a mess, so be it. Thanks anyway
              • tsbservice
                Field tech
                • 8020
                Remove side cover and check for small board sitting atop of main board. This is wireless module, check if it's not missing and snug fitted.
                Here is a link with picture from another model but wireless module can be seen - left bottom. Good luck
                Brother MFC-J4410DW Main PCB LZ4235B incl Wireless Module | eBay
                • galladr
                  • Sep 2022
                  • 9
                  Yeah. I check that. It seems to be ok. I checked on two others (100% working) but still nothing. 20230307 120519 — Postimages
                  I dont have another printer like this anymore to check that motherboard.
                  • Espert
                    • Mar 2023
                    • 1
                    The latest Firm is the one you have installed and it is not possible to find a previous one.
                    Have you checked if the region has it well configured in Maintenance???
                    code 74 -> 0103 in the case of Iberia
                    • Gift
                      • Mar 2011
                      • 2459
                      Perhaps it's just set up for wired network? I think in this case there is no wlan icon since it can't use both nics at the same time.
                      • galladr
                        • Sep 2022
                        • 9
                        El lunes checo. Gracias por la pista
                        • galladr
                          • Sep 2022
                          • 9
                          Nope. We already had printers Brother HL-L6400dw and they all worked fine. Only this one has problems with wlan. Unfortunately, they all sold out very quickly and I didn't have time to check out on another motherboard. If it's not a code region issue then (probably) hardware issue.
                          • Gift
                            • Mar 2011
                            • 2459
                            • galladr
                              • Sep 2022
                              • 9
                              If it can't be repaired, it will be for parts. We will probably have more of these models in the future. I'll check the code on Monday. Thank you for your help
