Brother mfc 9130 slide green tab on drum unit
  • lenovos
    • Oct 2012
    • 140
    i HAVE REPLACED DRUMS AND CLEANED TONER AND DRUM AREA. i AM A SHARP AND HP TECH MOSTLEY.
    i GOT MESSAGE TO CLEAR ONCE BUT IT RETURNED A FEW DAYS LATER. Also customer uses oem toner.
    I have also cleaned coronas on both old drums and new drums. Not sure what to do next. any help would be appreciated.
  • lenovos
    • Oct 2012
    • 140
    Re: Brother mfc 9130 slide green tab on drum unit
    Update I replaced the power board on the right side of the printer, It seems to have fixed it. I had a 9340 on the shelf and they appear to be the same board.
    • tsbservice
      Field tech
      • 8013
      Brother DR221CL, did you use it for replacement?
      • lenovos
        • Oct 2012
        • 140
        Hi yes I did
        • tsbservice
          Field tech
          • 8013
          Hi yes I did
          Ok thanks for sharing now it seems HVT board leaked probably due to drums over life or bad contact.
