I want to stop the property to give the report of the
  • abbas saeed
    • Mar 2010
    • 31
    The one who brother fax each time gives me a report Mnfrz which reduces the life of the ink and paper
    In fact, I want to stop these property
    (Off to give a report after each operation)
    I do not remember model but it is Brother Fax
    Help me
  • RRodgers
    • Jun 2009
    • 1947
    Stuff like that is usually called confirmation report. Just look in the settings I'm sure it's in there somewhere.
    • merryjohnson
      There are settings that are related to printer in the "control panel" printer options........You can check their and off it. I would also like to give you some recommendation of brother inkjet cartridges that are very cheap and you would also save a lot on them. You can use remanufactured brother inkjet cartridges, these printer cartridges are recycled from used original printer cartridges so you will not any problem using it as well.
      • abbas saeed
        • Mar 2010
        • 31
        thank you
