I have a Brother MFC-8300 that gives me a "Low Toner" message even after I put a new cartridge in. What could be the problem?
Brother MFC-8300 Low Toner indication
Try this, it work in most Brother machines.
This is a Toner Override, I think that it reset bias also.
1. Open the front cover
2. Press clear/options
3. Do not press 1. or 2. as per display said for Drum reset.
4. press *00
5. Accepted message will appear
6. Close and see if massage gone. -
4. press *00
Brother toner cartridges have flag gear on one side that push sensor inside the machine and says that new cartridge has been installed. Then machine counts limited number of copies (2k approximately). There is also optical sensor that "watch" throughout the bottom side of cartridge in case that spending more toner than anticipated (5% per page).
If you move that gear in starting position, and paint two transparent holes on cartridge (with pencil corrector), the printer will "think" that there is a new cartridge.Comment
Re: Brother MFC-8300 Low Toner indication
if the other two fixes dont work... try open front door.. cheat the sensor to close use a spring hook to manually move the reset sensor one second after you cheat the from door.Comment
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
Paul@justmanuals.comComment
