Machine Error
  • jlvelez
    • Nov 2008
    • 25
    [Error Code] Machine Error
    I have a Brother MFC-8860dn with a Machine error display and i can clear it and don't know what is the problem.
  • linuxxpwin
    • May 2008
    • 205
    What is the error display?
    • jlvelez
      • Nov 2008
      • 25
      it only display machine error. is their a button i have to press to know the code num?
      • linuxxpwin
        • May 2008
        • 205
        8.4.16 Machine Error Code Indication (Function code 82)
        Function
        This function displays an error code of the last error on the LCD.
        Operating Procedure
        (1) Press the [8] and [2] keys in this order in the initial stage of the maintenance mode.
        The LCD shows the “MACHINE ERROR X X.”
        (2) Press the [Stop/Exit] key. Return to the initial stage of the maintenance mode.
        • jlvelez
          • Nov 2008
          • 25
          the error is 71
          • linuxxpwin
            • May 2008
            • 205
            Originally posted by jlvelez
            the error is 71
            Laser unit defective Replace the laser unit.
            71 Scanner motor does not
            synchronize with the
            reference clock. Main PCB defective Replace the main PCB.
            check the above in the machine.
            • JustManuals
              • Jan 2006
              • 9838
              Just Manuals | The Internet's largest collection of manuals | Instant Downloads - Just Manuals | The Internet's largest collection of manuals | Instant Downloads
              Paul@justmanuals.com
              • linuxxpwin
                • May 2008
                • 205
                It can also be downloaded for Zero Dollars from the WWW. just have to know where to look.
                • linuxxpwin
                  • May 2008
                  • 205
                  Give a brother a break, he may not be a tech, but is curios about saving a few $$$. We all started this way at some point.
