Brother Printer HL 4040 Print unable error
  • abbas saeed
    • Mar 2010
    • 31
    how are you
    i have 2 brothers cmoes hl 4040 error (32) (20)
    1_ Brother Printer HL 4040 Print unable error 32
    2_ Brother Printer HL 4040 Print unable error 20
    help me
  • JustManuals
    • Jan 2006
    • 9838
    Re: Brother Printer HL 4040 Print unable error
    Paul@justmanuals.com
    • teckat
      • 16083
      Originally posted by abbas saeed
      how are you
      help me
      Best to call a service provider
      Print Unable 32
      click on link below
      How do I clear the message "Print Unable 32" from the LCD di : Brother
      Print Unable 20
      Check all your connectors. Turn the machine off and unplug it. Make sure it’s not plugged into a power strip. Let it sit for 20 to 30 minutes unplugged then plug it back in and try again. If that fails then most likely you will be finding yourself or calling a service provider to have the laser scanner assembly replaced.
      1 -Laser unit harness connection – Check the two harness connections of the laser unit and reconnect them.
      2 -Laser unit failure – Replace the laser unit.
      3 -Engine PCB failure – Replace the engine PCB ASSY.
      • copyguy123
        • Mar 2013
        • 10
        In my experience you are better off throwing the machine away. I tried fixing two of these one would work for a week or two and then the customer would bring it back. The other I ordered all the parts on the service updates after talking to tech support and never got rid of the error.
        • mona
          there is nothing but some manually problem for this so you can visit a engonnera
          • mem.npr
            I usually find it is the pad on the solenoid on the HVPS behind the fuser assy that causes error 32 on this model. Remove the pad or replace the solenoid to repair as it causes the CPR sensor cover to get stuck open.
            • jameschiu
              • Apr 2013
              • 11
              Check/replace the waste toner unit. A broken gear would cause this error message.
