i have a brother MFC-9450dn machine and just replace with a new drum unit, belt unit and fuser unit but it still state on the report 0%. can anyone please help me on how to reset the units mentioned>>>
how to reset Drum, Belt Unit & Fuser Unit for MFC9450dn
Re: how to reset Drum, Belt Unit & Fuser Unit for MFC9450dn
The drum & belt units are customer replacement items. Reset is menu>5>scroll to whay you want and reset. It is in the operators manual. The fuser unit is a tech replacement item. The reset procedure is in the service manual. I do not have this exact svc manual, so I'm going to wing it here. I think you press 3 & 9 at the same time which will take you to the reset menu, scroll to what you want and reset. Hope this helps.
justmanuals.com may have the manual you need. -
hi copiman, thanks for the info. i will try and advice on the statusComment
