Brother MFC 9840cdw print unable 2A
  • bbahnsen
    • Sep 2013
    • 7
    [Error Code] Brother MFC 9840cdw print unable 2A
    I have replaced belt sensor, density sensor, transfer H.V.P.S., waste box,transfer belt and still get error. Any ideas?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Brother MFC 9840cdw print unable 2A
    Paul@justmanuals.com
    • bbahnsen
      • Sep 2013
      • 7
      I have tried replacing the drive train per brother tech support, this did not fix either.
      • bbahnsen
        • Sep 2013
        • 7
        problem resolved, it proved to be the belt release solonoid
        • Doug James
          • Jan 2012
          • 935
          Thanks for this posts BIG-TIME. I pulled the "Belt Cleaner release assembly" and stretched the solonoid spring and cleaned the sensor and it works GREAT.
          • thankful4help
            You all are awesome for posting this! I wanted to add what helped me get this done. Sorry for dumbing it down (I'm not a printer tech). Little white piece was sticking to foam (sticky surface) when spring compressed, so I put a tiny piece of clear tape over this sticky foam. I also stretched the spring a bit to help it return. Thank you again, and I hope this helps someone else like me. Also, I found another description of how to get to this part (Google MFC-9400CN Print Unable 2A FIX).
            • theengel
              • Nov 2011
              • 1784
              Yeah all the foam pieces on the solenoids for this machine are going bad now. Seeing a lot of these calls. Pretty easy fix considering there's no metal involved... you can get away with just peeling off the foam and that's it.
              • mayabee
                Can you please indicate how to do this? I am having the same problem and do not know how to locate it to fix it
                • tonerjockey
                  • Apr 2014
                  • 567
                  Thanks for have info also very much.quite helpful.I really appreciate it.have a nice weekend, Jim
