hello
i have a RISO KS500 machine with feed problem.if command to print,the drum rotate but the feed unit motor or even the feed rollers wont rotate to pick the papers.but if i trie to make the master the machine working fine to make the master on the drum,but fail to print even the first copy after master making process.
anyone know please hel
