brother mfc8440 maintenance needed print unable #32
  • DOE
    • Mar 2010
    • 258
    this is a update to earlier post. customer just gave me all of the info. it says maintenance needed print unable #32 on screen. not familiar with brothers so any advice would be apreciated
  • Dickie
    • Nov 2011
    • 190
    Re: brother mfc8440 maintenance needed print unable #32
    If this is the colour laser machine this fault is usually caused by the shutter on the transfer belt alignment sensor sticking.
    It is located under the fuser at the rear base of the machine and is usually covered by a couple of screw on or clip on metal & plastic covers.
    Once you have removed the fuser and can see the start of the transfer belt at the rear you are looking for the sensor that is just underneath the back edge of the belt, this has a solenoid operated shutter which is normally the problem.
    • Elmtech
      • Nov 2013
      • 155
      Just looked in the service manual for that error and it doesn't exist. The errors start in the 50's. Either the model is wrong or the error code is. Can you recheck with the user and repost.
      • dbrownlee
        • Sep 2005
        • 197
        This is correct. Machine error 32 is an inkjet service code that deals with the travel of the print head due to various problems- debris, improper maintenance unit operation, etc.
        Good luck, Dave
        GO TIGERS!!
