Brother MFC 9970 cdw op panel
  • vstar
    • Aug 2007
    • 176
    [Misc] Brother MFC 9970 cdw op panel
    Hi all its been a while. I'm sure this is probably an easy one but I can't seem to figure it out, please help.
    I can not figure out how to remove the control panel on this machine, it looks like I need to remove the scanner but it looks like there are screws under the control panel that need to be removed first.
    Please what am I missing?
    I need to remove it for a code of CE, I found out that is for the control panel.
    Thank you
    Cameron
  • ubmchrisb
    • Dec 2014
    • 7
    Re: Brother MFC 9970 cdw op panel
    The actual surface of the panel removes by unhooking. Then there are 4 screws underneath. The bottom edge of the lower part of the panel is hooked. Once it is unhooked it can be lifted away and the harness unplugged.
    • vstar
      • Aug 2007
      • 176
      Thank you, I will try that.
      Cameron
      • tonerallover
        • Aug 2011
        • 7
