I am trying to repair printer for a client. They had brought in the printer because it was not crinkling papers in large print jobs and during those large print jobs the toner wasn't always properly fused to the paper. The fuser roller was very wrinkled which upon further research was suggested to be replaced. The replacement fuser assembly worked great. The only issue client reported was that duplex pages often had toner splotches on the back. This problem was cause by when toner leaking into the printer when the client transported it back to their location. It was brought back into the shop and one of the techs sprayed out the inside of the printer with compressed air. It printed fine for a few pages and it did appear to correct the issue with the toner splotches, however we noticed an increase in paper jams. The printer now jams after only printing one sheet. It doesn't matter if it is duplex or single page mode or a copy job or a print job. The results are always the same. The first page prints and then the second page will be partially through the fuser unit and a third page will be being picked up from the paper tray. The second page is normally about 2-3 inches out of the fuser. What is strange is that the printing on the second page is that it starts about 3 inches lower than what it should be and how it prints on the first page. The printer also reports a paper jam if I am only doing one copy, even though the copy comes through just fine. If I open the printer is does not have any stuck pages when only doing one copy. It also reports this error even if I only have one sheet in the paper tray. These issues happen both in the regular paper tray and the manual feed tray.
I did try the old fuser unit again and the paper jam issue occurs with that as well.
Any input would be great. Thank you for your help!
