Brother 2820 error
  • kmguy31
    • Aug 2008
    • 11
    Brother 2820 error
    screen reads "unable to print, refer to users guide" checked the guide, says power off/on. tried. let sit for a few hours. tried again. same thing. machine has only been in the field for a 3 weeks. any ideas?
  • raym
    • Apr 2005
    • 62
    you can try doing a reset by entering "menu/set" & "*2864" all within 2 secs. you should see "maintenance" on screen. if not, try entering code again. once in maint. mode, enter "91". should say "parameter init." enter "99" to exit. if there is a true problem, you should see some sort of code pop up.
    hth,
    ray
    • kmguy31
      • Aug 2008
      • 11
      thanks, tried that. no help. kicks me back out to the same screen reading "unable to print"
      • jtymabel
        • Aug 2008
        • 164
        menu, * , 2,8,6,4 and then 82.. should give you error code log or list. then let us know...
        • jtymabel
          • Aug 2008
          • 164
          also check the back door to make sure the paper flag is not broken.
          • E Winter
            or try service function 01 for full factory reset
