MFC-J415W
  • gohkahwai
    • Jun 2014
    • 4
    [Error Code] MFC-J415W
    Unable to clean 50,ask remove the jammed paper.no paper inside.
    cannot reset.
    Pls help
  • laitang
    • Nov 2012
    • 627
    Re: MFC-J415W
    Brother MFC-JW415 Unable to clean 50.JPGBrother MFC-JW415 Maintenance unit.JPG
    • theengel
      • Nov 2011
      • 1784
      Re: MFC-J415W
      The most you can probably do is take it apart and look for something that doesn't look right. If nothing is obvious, the machine is likely finished.
