CLJ CP2025 Cartridge tray stuck.
  • JERRY D
    • Mar 2009
    • 31
    I've had two products with the same issue within the past week. First a Canon Image Class MF8350Cdn & now this HP. They both use the same tray assembly. It appears the black cartridge was not installed in the tray correctly & is preventing the tray from opening. I can't see any way to get the tray to pull out without breaking something or tearing the unit down from the top. Any hints from someone who's overcome this issue?
  • theengel
    • Nov 2011
    • 1784
    Re: CLJ CP2025 Cartridge tray stuck.
    Tell the cust:
    "Sorry, since someone jammed a cartridge in there like this, I'm gonna have to just pull it out and then fix whatever breaks in the process."
    • subaro
      • Oct 2010
      • 1274
      About 1.44 min into the video above, you see the white latch that locks the drawer to the machine. this may be stuck there and i think you have to use your wits to pry, wiggle at that latch and the rest to get the drawer unstuck. I have had these situations in may different situations, like printer trays not opening ect. and there is just no one answer. you are on your one on this one i think.
      here is a video also of a guy doing a teardown of this machine but he must have taken out a million screws with a non-powered thing. good luck
