HP 4700
  • Users Tech
    • Nov 2013
    • 85
    HP 4700
    hi all,
    need help with HP4700DN with duplex. problem: "13.12.00 jam in duplex path". i bought plenty of these printers based on recommendations that this is a solid printer which is true although it's an old model but the prints are very good. i tried about 4 printers and all has the same problem when printing duplex. duplex setting is on. i also checked "print on both side" in the printer settings. i also took out about ten duplex from my other stocks and tested it on the 4 printers but the problem is the same. it looks like the small rollers at the back side of the etb doesn't turn and can't pull the paper down causing the jam.
    please help. thank you.
  • theengel
    • Nov 2011
    • 1784
    Re: HP 4700
    You've got the duplex tray, and then the duplex feed on the etb. Replace the etb and see if it fixes it.
    • Users Tech
      • Nov 2013
      • 85
      Re: HP 4700
      yes i have the duplex tray on top of the printer and duplex feed with small rollers on the etb and i already replaced it with 3 etb's but the problem is the same. the duplex feed rollers on the etb does not turn causing the jam because it cannot pull down the paper. it looks like the board in the duplex unit is controlling the duplex feed rollers. the paper comes out of the duplex first then when it goes back to the printer and pass by the duplex feed rollers on the etb, it stops/jams.
      • theengel
        • Nov 2011
        • 1784
        Re: HP 4700
        Did you look through this:
        Solution for a 13.12.00 Duplex Path error on a Color LaserJet 4700dn
        • Users Tech
          • Nov 2013
          • 85
          Re: HP 4700
          thank you theengel. i will try their solutions. hope it works for me.
          • prntrfxr
            • 1622
            Re: HP 4700
            I know this probably doesn't relate to your problem because yours is feeding, but I had one 4700 that recognized the duplex unit, had a good ETB, but wouldn't duplex at all. Turned out to be the connector in the printer that the duplex unit connects to, was bad.
            • Users Tech
              • Nov 2013
              • 85
              Re: HP 4700
              sometimes we just miss simple things!
              i found the solution here:
              many thanks!
              thank you theengel and prntfxr..
              best regards..
              • Printerdude
                • May 2015
                • 119
                Re: HP 4700
                The eleventh time is the charm! Thanks for sharing you results, very few shares the results of there fixes, most just ask for help and post nothing afterwards.
