hp laserjet cm6030 transfer are jam
  • akhait01
    • Apr 2011
    • 58
    Hello and thanks ahead for all of your help. I purchased this printer about a year ago and it worked perfect with no jams until very recent. It jams on every print 13.05.00 transfer area jam, the paper is bend every single time at the edge. I am lost and i need this printer up and running yesterday. I greatly appreciate all of your help. thanks.
  • theengel
    • Nov 2011
    • 1784
    Re: hp laserjet cm6030 transfer are jam
    Probably the fuser. You'd have to look at the paper and see what it's catching on.
    • akhait01
      • Apr 2011
      • 58
      I thought so too and replaced the fuser already. Still same problem.,
      • akhait01
        • Apr 2011
        • 58
        So here is what i discovered so far. In the sensor test mode, the printer prints without jamming. As soon as i exit the troubleshooting menu, it jams on every print. I am at total loss. Please let me know what you guys think.
        • _SuabE_
          • Jan 2008
          • 108
          How is the condition of the transfer assembly lock when you closed the green handle there is a 2 plastic hook front and rear see if it is holding, it happens to me one lock is broken..
          Good luck
          sigpic
          Senior Technician Specialist
          A+; Network+
          Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
          Printer Handled: Canon, HP, Epson, Brother, Samsung
          Duplicators: Risograph, Duplo
          • subaro
            • Oct 2010
            • 1273
            I repaired one of these a couple of months ago. did not have jams, but finisher wheel fallen off and had to bend, drill ect. to get it up and running. had a thin line of smudging and using the test modes soon found the transfer belt cleaning blade needed just that, cleaning.
            Excellent colour quality from this machine.
            This machine has comprehensive troubleshooting diagnostics, that can help in isolating problems.
            Does it only jam when printing from the computer ?. print the configuration pages for the machine and see if it jams then. It does not bend the paper in test mode, does it. you can program it to stop at certain points to see where the bend in the paper may be originating.
            check your paper settings in your print driver, check the paper type is correct.
            PAGE 596 of the service manual.
            Print/stop test
            Use this diagnostic test to isolate the cause of problems such as image-formation defects and jams
            within the engine. During this test you can stop the paper anywhere along the printer-paper path. The
            test can be programmed to stop printing internal pages or an external print job when the paper reaches
            a certain position. The test can also be programmed to stop from 0 to 60,000 milliseconds. If the timer
            is set to a value that is greater than the job-print time, you can recover the printer in one of two ways.
            1. Touch Administration.
            2. Scroll to and touch Troubleshooting.
            3. Scroll to and touch Print/Stop Test.
            4. Select the appropriate number of milliseconds and then touch OK.
            • theengel
              • Nov 2011
              • 1784
              can you take a picture of where exactly the paper is jamming?
              • Printerdude
                • May 2015
                • 119
                A little more information needed. Is the paper stopping right at the fuser? does it go into the fuser? Does it reach the fuser? You mention the paper is bend, is there print on/in the bend? How big is the bend? Does bend mean folded?
