What would you choose ....?
  • savi0r
    • Sep 2010
    • 363
    [Misc] What would you choose ....?
    Hello guys. I need some advice. What would you choose between a hp pro 400 m425dn and a brother 8510/8520? I am quite a fan of the brother brand, but some say that between those, they would choose the hp. What are your thoughts about it?
  • theengel
    • Nov 2011
    • 1784
    Re: What would you choose ....?
    You'll find some inherent fuser problems with those Brothers. If it's a business setting, I would stay away from them.
    • Blizzoo
      • Aug 2013
      • 607
      Go for hp, like above , fusers are a problem on Brothers. I have a client with 8 HL-5440 and 6 of them have fusers changed within 30k-45k. These particular fusers are built with fuser film sleeve and heated with a lamp like those with heat rollers !?
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        I would stay with HP.
        • bob marley
          • Jan 2012
          • 1339
          I'll choose Hp
          Live for yourself and you will live in vain. Live for others, and you will live again
          • savi0r
            • Sep 2010
            • 363
            Thanks alot guys. Brother uses heat rollers for fuser and on these models, i have seen worn fusers at about 70-80k prints. But the hp has supperior memory and the only consumable is the cartridge. So they say. And it's a lot smaller and less noisier than brother.
            • Blizzoo
              • Aug 2013
              • 607
              Well this was not a question, i made a spelling mistake...they are like I said
              Good choice on hp though
              • savi0r
                • Sep 2010
                • 363
                Anyway, i went friday to a client with a hp pro400. It had paper jammed in the adf and the user pulled it out. Now it gives all kind of errors like: the scanner couldn;t calibrate, adf door open and other stuff like that. You have acces to nothing in the adf. And i heard these models have sensors wich are particularily very sensitive. Maybe you are right about the 8510,8520. What about those brother mfc's wich are built in the hl 5250 or 5340. I changed the heat roller on those at about 100k.
                • subaro
                  • Oct 2010
                  • 1274
                  HP has made some really nice machines, but also some terrible one. who remembers the 4100 mfp, a nightmare machine with calls every week or so for scanner, fax and nic issues. also the hp 9000. these machines is a love-hate machine. when they are running good the are really nice, but when trouble is calling, you could be there hours especially if there is a finisher hooked up.
                  choosing these small mfp's, i would be looking at the cost for parts and toner really, and the features you want.
                  • theengel
                    • Nov 2011
                    • 1784
                    The truth is, both of these are crap machines--almost throw away units. I say HP because a client of mine bought a bunch of Brothers instead of HPs, and almost half of them were putting creases in the paper from the fuser--this is right out of the box. It happened mainly when the customers were running more than 10 prints at a time. They made the switch to HP. That was about a year ago. Finally, last week, I had my first call that actually required parts. The HP unit needs a new fuser & ADF unit, after 180,000 prints.
                    • qbert69
                      • Mar 2013
                      • 1152
                      I'd go with a Kyocera!
                      In Japanese:
                      Kyo = Cut
                      Cera = Ceramic
                      They originally started with R&D for making ceramic knives!...They carried that over to make materials for their xerographic technology, the imaging drums that are 98% the hardness of a diamond!
                      REACH FOR THE STARS!!!
                      Konica Minolta Planetariums!
                      • savi0r
                        • Sep 2010
                        • 363
                        What were the regular service calls about? Just curious.
                        • theengel
                          • Nov 2011
                          • 1784
                          More often than not, it was the generic ctgs they were using.
                          HP Laserjet M400 MFP Jams
