Hp color lj 4700
  • Orion2010
    • Jun 2015
    • 176
    Hp color lj 4700
    hello to all,
    i have problem with hp color lj 4700 4700.JPG4700.JPGHP 4700.JPG any idea ?
    thanks
  • theengel
    • Nov 2011
    • 1784
    Re: Hp color lj 4700
    Fuser
    • cscce
      • Jun 2014
      • 156
      Bad Cyan cartridge.
      Originally posted by Orion2010
      hello to all,
      i have problem with hp color lj 4700 [ATTACH=CONFIG]31527[/ATTACH][ATTACH=CONFIG]31527[/ATTACH][ATTACH=CONFIG]31528[/ATTACH] any idea ?
      thanks
      • subaro
        • Oct 2010
        • 1273
        How do you troubleshoot problems like these. well for starters, the machine has a comprehensive diagnostic menu that prints and test functions. did you look into this menu. One said fuser and the other cyan cartridge. I would go by the process of elimination. lots of HP techs out there, lets hear from you on this one.
        • theengel
          • Nov 2011
          • 1784
          The problem is happening with all the colors. You can't see it as well, but the magenta & yellow both have spots on them. The reason the big blue areas are so bad is because both black and cyan are in that area. Since there's white underneath, it means it's not a cartridge... otherwise one of the colors would still be visible beneath the missing cyan.
          It's a fuser.
          Also, you can see, right by where the finger is, the yellow reappears.
          It's a fuser.
          • pravin007techno
            • Aug 2014
            • 7
            may be the printer drivers are corrupt.
            • lplandin
              • Jan 2016
              • 28
              hello to all,
              thanks
              Machine is not fusing, if you are using thick paper change the settings to card stock and that should take care of your problem, if not replace the fuser unit.
