hp 2550L LIGHT ON ONE SIDE
  • copierlady
    • 338
    Hp 2550l customer says they only changed the yellow cartridge and now it is faded on the right side of the prints. Tryed to change yellow cart. From another printer i have in the shop but machine will not accept it ( i guess the chip and the page count thing) i had this same problem with a canon ic mf 8170 few weeks ago with mag. Cart. (they are almost the same machine) never did figure it out the only feed back i really got on the canon was that it was a problem child with lots of issues. Like the name says i'm a copier lady! Any ideas?
  • jtymabel
    • Aug 2008
    • 164
    is it just the yellow thats faded or all the colors?
    • prntrfxr
      • 1622
      yellow is probably going to be worse. First blow out laser scanner lens openings.
      1. perform carousel alignment (easy) - check if cartridge arrows line up with arrows on printer.
      2. Replace carousel bushing
      3. replace carousel asm (lots of time required probably wont be worth it)
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • copierlady
        • 338
        THANKS
        Thanks guys the color tip helped when i looked closer i saw that the only thing realy missing on the print was black. When i checked the cart. It was bound up. Just a coincidence that it was at the same time they changed the yellow. (something the customer will never believe!) but there is also a yellow mess inside i have to clean up. Is there anything i need to know?
