Hp laserjet 600 does not take firmwar
  • Orion2010
    • Jun 2015
    • 176
    Any idea
  • 1stcavvet
    • Apr 2015
    • 231
    Re: Hp laserjet 600 does not take firmwar
    If you mean it won't accept firmware from a thumb drive thru the port in the front, then you need a hard drive and redo firmware, instead of the card that's in there I've used a thin hard drive from a laptop and stuck it inside the case, same connector. If you're bringing firmware down from a web site then you probably still need a drive. I never did it that way on the 600's GOOD LUCK
    • jper34
      • Sep 2011
      • 225
      Im not supergood withcomputer/network stuff, but Ive had to upgrade firmware, and the trublewe ran into, was the size of the usb drive, I think we had to have frmware on an 8g or less , size usb. also make sure the new firmaware is exploded on the thumb drive, it cannot be in a folder..good luck,mate,let us know what you find..thanls
      Jaime Perona
      Indep. Copier Svc.
      • Orion2010
        • Jun 2015
        • 176
        Jaime Perona
        Indep. Copier Svc.
        • Iowatech
          Not a service manager
          • 3930
          It is actually pretty important that you read the firmware "read me" file before you actually start the upgrade.
          I don't know how much this will help, but here's the English language version of readme for the latest firmware upgrade for that series:
          readme_ljM601_602_603fw_2307851_000040.pdf
          • Wild Bill
            • Jul 2005
            • 774
            This is how I do it. This is for if your coding and cant come to ready.
            HP M602 Pre-Boot Walk-Up Method (USB) Firmware Install | Do-It-Yourself Printer Repair
            There are other ways also using USB thumb drive in the maintenance menu. Or via Network.
            I carry a Thumb drive it's much faster/ easier
            Izzy
