HP ScanJet 8270 main board needed
  • techathens
    • 83
    Looking for a main board for a HP ScanJet 8270 Color Digital Flatbed Scanner. Part Number: 105-1204-9
    Thanks.
    Salesout Pro
    SalesoutPro@gmail.com
  • prntrfxr
    • 1622
    Part number is not a good number. HP part numbers are usually XX#-#### format. Double check part number and I'll check for you. Will let you know as soon as I know. If you find it in the mean time let me know. If I get it you could come p/u because you're in local area - save shipping as I'm in Norcross.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • techathens
      • 83
      That part number came from the board - so it may be the manufacturer's number, I'll look at the manual and get HP's #. Thanks for the reply!
      Salesout Pro
      • prntrfxr
        • 1622
        check your email - I think I found the part #. Just click your own name to see it.
        • prntrfxr
          • 1622
          I think it is the:
          Interface SCSI Module P#: L1977-69001. (only other parts listed are power module, scanner, roller kit, & an ADF asm) If its something other than this I'll need the correct part number to locate.
