6040 reset roller kit
  • roho
    • Mar 2009
    • 844
    [Misc] 6040 reset roller kit
    After replacing a rollerkit on a 6040, I am not able to reset the counter. I've put in a secondary assembly as ordered by the tech who first went to the call, the device has the latest firmware, any suggestions? Thanks!
  • theengel
    • Nov 2011
    • 1784
    Re: 6040 reset roller kit
    Did you try googling it?
    Solved: CM6040 roller kit out - HP Support Forum - 5072697
    • roho
      • Mar 2009
      • 844
      I did see that, however the housing was replaced. I returned and inspected both the old and new housing, didn't see any problems with the spring. I replaced the transfer roller with a new one and the message cleared. I guess the first roller had an issue. Thanks for the tip!
      • subaro
        • Oct 2010
        • 1274
        Next time around, you should post the entire and correct model of the machine. There is no hp 6040 . There is however a CM6040. One could imagine or guess the model, but that would be wasting time if is was not the one you were referring too.
