Laserjet 1320 tray 3 solenoid
  • ChrisG
    • Oct 2013
    • 181
    Do any of the HP Guru's out there know what the part number is for the pickup solenoid in the additional 250 sheet tray 3? All of our parts suppliers only show tray 3 available as an assembly. Is this truly the case or is that solenoid used in other places?
    Help always appreciated
    Chris
    TJL Copy Products
  • Wild Bill
    • Jul 2005
    • 774
    Re: Laserjet 1320 tray 3 solenoid
    Parts book only has tray 3 as the complete assy. PN Q5931A.
    That said Tray 2 feed solenoid may be the same you need to inspect and see if it is. PN RK2-0424 Tray 2 feed solenoid.
    I would take it out and fix it. I'm assuming you are replacing it because the felt is turned sticky. Clean old felt and replace with new felt or electric tape. Don't leave it bare or it will cause jamming.
    Good Luck!
    Izzy
