Admin Tab
  • KMOCEtech
    • Feb 2013
    • 6
    [Misc] Admin Tab
    Guys, does anyone know how I can access the admin screen on a HP M4555 MFP ? Its not showing on the LCD display?
    Cheers
    J
  • qbert69
    • Mar 2013
    • 1152
    Re: Admin Tab
    If it's networked, perhaps through a web browser?
    Just an "educated" guess!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • BobR
      Re: Admin Tab
      Besides the web browser. you may have to sign in to gain access to the secured features.
      The user name should be ADMIN and the password is typically blank by default.
      • KMOCEtech
        • Feb 2013
        • 6
        Re: Admin Tab
        Hi Bob, I did try ADMIN as password, using both upper and lower case. This did not work. Thanks all the same.
        • johnyb
          • Feb 2011
          • 167
          Re: Admin Tab
          You will need to log into the web browser and turn the option to display the admin menu on the operation panel , back on.
          Usually Admin - no password or admin admin as stated above otherwise someone has set it, probably some IT guy....
          Last option if you do not know the password is a cold reset / or NVRAM clear - sorry!!!
