M3035 ADF problem
+ More Options
Posts
  • cscce
    • Jun 2014
    • 156
    [Jamming] M3035 ADF problem
    I'm working on a HP M3035 MFP. When scanning double-sided using the ADF it works fine if only a single sheet is fed. But if multiple sheets are in the feeder it fails to scan both sides of all sheets and ultimately prints fewer pages than were in the ADF (i.e. when feeding 3 double-sided pages only one or two get printed). No error message appears.
    Mechanically everything in the ADF looks fine.
    Any ideas?
  • Alfons
    • Sep 2016
    • 9
    Re: M3035 ADF problem
    HI cscce,
    Did you found a solution ? I have the exact problem and all the gears are ok. It is feeding the second page before finishing the first page and that goes to a jam.
    Thanks !
