HP laserjet pro m521 making noise
  • ldfrepairs
    • Oct 2012
    • 148
    Load grinding sound when turned o or making copies. sounds like coming from the Fuser area. cannot find cause all gears are in good condition. any suggestion would be appreciated. Thanks
    drugstore-onlinecatalog.com
  • theengel
    • Nov 2011
    • 1784
    Re: HP laserjet pro m521 making noise
    It's usually the lower roller bushing that wears, which causes the gears not to mesh correctly. So start with the fuser... then the fuser drive gear set (if any exists for that machine). You won't actually be able to see the wear on them.
