M525 30.03.23 error
  • rsherzer
    • Jun 2025
    M525 30.03.23 error
    Working on an m525 with a 30.03.23 error. Power cycling causes code to go away but keeps coming back periodically. Thoughts??
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: M525 30.03.23 error
    It's scanner calibrate failure.Inspect underside of the glass.I'm not sure if this model have label which is used to calibrate the scanner. Maybe is falling off the glass.Clean inside the glass and upgrade last firmware.
