HP M603error 59.00.30.
Hi. Thiscode indicate a faulty paper feed motor. I have executed a component check and the paper feed motor works ok, the drum motor doesnot turn, the fuser motor does not work but you can hear a click of a relay. Ihave also checked motors removed from housing in case something is jammed.
I haveremoved formatter and did an engine testI can hear a click of a relay but does not work.
I havechanged drum motor, dc controller board,high voltage board.
Am I missing something?
Can anyonehelp?
Gordie
Can anyonehelp?
Gordie
