M452nw faded page
  • clw@solutiononenow.com
    • Mar 2014
    • 13
    M452nw faded page
    Anyone know what would cause it to get mishandled page, print a faded page, run cleaning cycle then reprint same page?
    Doesn't register in event log.
  • theengel
    • Nov 2011
    • 1784
    Re: M452nw faded page
    I don't know about the faded page.
    I do know that if the pickup isn't perfect, it'll run for a while, and then reprint the same page (sometimes, it'll run a 'cleaning page' before reprinting).
    On some of these, if I'm not using OEM rollers, I have clean the new roller with rubber cleaner (I actually use Goo-off, bought from Krogers), then clean it with windex before it works.
    • Wild Bill
      • Jul 2005
      • 774
      By "mishandled page" Did you mean Mispick?
      Replace paper feed rollers as a set. Pick up, Feed and separation rollers.
      If it doesn't feed into the registration rollers correctly it will go into cleaning mode. its cleaning all the toner laid down on the transfer "ITB" and then will keep doing this untill it feeds correctly.
      Agree with theengel. I would only use OEM rollers, I have enough stress in my life.
      Izzy
