HP M451nw
  • Wieslaw
    • Jul 2025
    [Misc] HP M451nw
    How to change page counter (color mono and total) on HP M451nw printer after replaced formatter board .
    Need script (PJL )
  • austonrush
    Sharp & HP Tech
    • 234
    Re: HP M451nw
    To do this you have to have the printer shared and know your computer name. You would then use the command at a dos prompt of:
    Netuse lpt3: \\computername\sharename
    You substitute the name of your computer and the sharename you have given the printer. If you get the command loaded successfully then you would copy the file to lpt3.
    Use this Attached Doc serial.doc Edit the file using the DOS editor to substitue your correct serial number and other info.
    You then would type at the command prompt: copy serial.doc lpt3 and hit the enter key.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: HP M451nw
      I can not imagine why is the counter so important on a cheap desktop printer? I do not want to be rude,just curious.
      • Wieslaw
        Re: HP M451nw
        Use this Attached Doc [ATTACH]37626[/ATTACH] Edit the file using the DOS editor to substitue your correct serial number and other info.
        HI .
        I have WebJetAdmin softwatr .
        I know how to send file , I need file ( Notepad++) example.
        ESC %-12345x@PJL SET SERVICEMODE=HPBOISEID
        @PJL SET PAGE=900
        @PJL SET SERVICEMODE-EXIT
        Wes
        • Wieslaw
          Re: HP M451nw
          When you will have 200 printers and charged users for printed pages , you will know why .
          Page counter is very important for me.
          I need script wrote under Notepad++
          Wes
          • zoraldinho
            • Mar 2008
            • 5015
            Re: HP M451nw
            Wes
            Formatter costs 80% of the printer and you spend probably many hours to realize that failure is on formatter.
            • austonrush
              Sharp & HP Tech
              • 234
              Re: HP M451nw
              HI .
              @PJL SET PAGE=900
              Wes
              I gave you the notepad example. It is a hyper link attachment in my last post.
              • Wieslaw
                Re: HP M451nw
                I now how to change serial number.
                I do not now how to change color and mono page counter(after replaced Formatter board)
                Thanks for your reply .
                • zoraldinho
                  • Mar 2008
                  • 5015
                  Re: HP M451nw
                  From service manual
                  WARNING! Do not install a replacement formatter PCA and DC controller PCA at the same time.The formatter PCA and the DC controller PCA store important product configuration information(NVRAM data) that is lost if both PCAs are replaced at the same time. When the product power isturned on, the DC controller restores the NVRAM data on the replacement formatter.
