HP CM1312 MFP
  • Lagonda
    • Aug 2008
    • 1649
    HP CM1312 MFP
    Hi guys,
    I've just had a HP CM 1312 MFP dumped on me that I know nothing about and cant find the ops manual.
    How do you change the fax from manual to auto answer?
    Cheers,
  • prntrfxr
    • 1622
    HP CM1312 MFP
    Finally got my hands on one. Hope this info helps you. From the user guide.
    Use the control-panel menus
    To gain access to the control-panel menus, use the following steps.
    1. Press Setup.
    NOTE:
    To access the function specific menus (HP LaserJet CM1312 (fax/photo-card model)
    only) press
    Fax Menu Copy Menu Scan Menu or Photo Menu.
    2. Use the arrow buttons to navigate the listings.
    Press OK to select the appropriate option.
    Press Cancel to cancel an action or return to the Ready state.
    Control-panel Setup menu
    These sub menus are available from the control-panel main Setup menu:
    Use the Copy setup menu to configure basic copy default settings such as contrast, collation, or the number of copies printed.
    Use the Reports menu to print reports that provide information about the product.
    Use the Fax setup menu to configure the outgoing and incoming fax options and the basic settings for all faxes.
    Use the Photo setup menu to configure the basic settings for printing photos from a memory card.
    Use the System setup menu to establish basic product settings such as language, print quality, or volume levels.
    Use the Service menu to restore default settings, clean the product, and activate special modes that affect print output.
    Use the Network configuration menu to configure network settings such as TCP/IP configuration
    Go to the Fax set up menu,Basic setup, & then select one of the following:
    Answer mode
    Automatic
    TAM
    Fax/Tel
    Manual
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • Lagonda
      • Aug 2008
      • 1649
      Cheers Mate!
      The only problem is that that was 6 weeks ago...........if only I could remember who the customer was!!!
      • prntrfxr
        • 1622
        HP CM1312 MFP
        lol...I had to fight with the boss to get a manual. We're going to need it so I convinced him. He did one better and got us ASP status, which means I can get all of them free. Knew I'd run a long shot that you'd remember the post let alone still have the call, but gave it the old college try anyway.
