I am having a problem with Tray 2 not lifting. Its not seeing the papertray.
HP LaserJet M608 Not seeing Tray 2 "Tray 2 overfilled or roller issue"
Re: HP LaserJet M608 Not seeing Tray 2 "Tray 2 overfilled or roller issue"
I had one "Out Of The Box" Doing that.
Facing the printer, left side paper guide, that has the size sensors was out of position. The screw from the factory was loose so it popped out . I popped it back in, Tightened the screw and that fixed it.
The paper lift motor won't rise if the actuators don't get made.Izzy -
You are not talking about the paper tray right? When you say the right paper guide? I switch paper trays and it did the same thing.Comment
Did someone mentioned right paper guide? I read left paper guide.Comment
The paper lift motor won't rise if the actuators don't get made.Comment
