HP 9250 digital sender, can't see it's HD
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    This digital sender was brought in and I was told it did not work, customer did not know why. I found that the Hard drive in the machine was not plugged in. I think the customer may have swapped it out before bringing it to me. The HD test OK and we formatted it, but when installed in the machine, the machine says it cannot send or recieve because a drive is missing. Is there something I have to do to the HP to make it see the HD?
  • prntrfxr
    • 1622
    I'm not going to be much help I'm afraid. I dont have any experience with this machine. It it was strictly a printer and I had this problem I would perform hard disk initialization (whether formatted or not), perform cold reset with all optional devices removed, and upgrade firmware. Whether you can do that on that machine, I have no idea.
    Since its not a printer, I would suggest obtaining a service manual as a first step. Please post the fix, cause I'd like to know and I got a feeling we're going to run into this again.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      I am looking to get a manual. One of the issues I have is that in the past when I have put a hard disc in an HP I have been prompted by the machine to initalize the disc, or have been able to find it in the menue. No such luck here. And you are correct about seeing the problem again, HP makes a lot of money on these and is no help in getting them fixed.
      When these machines have issues, they really have issues.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Just as an update- I obtained a manual, it was no help. My plan is to replace the main board that the HD plugs into. Waiting for customer approval.
        • Gleq
          • Feb 2007
          • 72
          hi fixthecopier
          please i need this service manual badly and i would appreciate it if you can send me a copy will email: deoarhin@yahoo.com
          thanks
