hp m1120 isn't fuse toner!
  • Nikola Karamanov
    • Apr 2016
    • 58
    Hi guys! I have problem with Hp LaserJet M1120, after replace the fuser sleeve, the toner wont fuse on the paper(smears). I measured the heat element - its OK, the lubricant its ok! Is it problem that I use compatible sleeve? can it be the pressure roller?
    Re: hp m1120 isn't fuse toner!
    take it back out.. recheck your work.. you screwed the pooch.
    • theengel
      • Nov 2011
      • 1784
      Generally, if you replace the sleeve, you should replace the heating element also.
        exactly.. but some.. well?
        if the sleeve rips.. MAJORITY of times on this model ( some others ) total heating element is needed. it screws with the resistors on the bar.
        cheap lil printer.. wouldn't waste more time nor $$$ on it.
        hopefully he put more greee on the bar than what came with the sleeve.
        • Nikola Karamanov
          • Apr 2016
          • 58
          I was try with other heat element, little bit better but again isnt fuse the toner.
