HP 4200 scanner or mfp815 - keeps saying log in as administrator
  • pbrooks259
    • Jun 2017
    • 162
    I need help on an mfp815 or4200 scanner. I have 2 of them and both do not recognize a scanner. With the PC on, when I power up the scanner it says "you do not have sufficient security privileges" or something like that. Then says to log out and back in as administrator.... I guess I am not doing it properly because it keeps saying to log in as administrator. What I am doing wrong? Hope you can help.
    Re: HP 4200 scanner or mfp815 - keeps saying log in as administrator
    You haven't logged on as administrator you must logon using admin account.
    • pbrooks259
      • Jun 2017
      • 162
      Thanks, Phil. I'll check into that.
