Re: Anyone successfully clone a Designjet hard drive?
It is a very old method but if you can get a utility that can do absolute sector copying it is possible. I used to use Norton Utilities under DOS.
Hi All
This is a very informative thread. Than you for keeping these old horses alive. I have a designjet 1055cm plus I am trying to resurrect. I replaced the drive years ago and forgot how I did it. The drive appears to be working but I wanted to clone it just in case of failure. It has been about 8 years. I am having trouble trying to burn an image but am still trying. Does anyone have any tips for cloning? I am using an ide to usb adapter in clonezilla but I am having issues with copying an image of to a file. I only have 1 ide adapter so I can't try disk to disk. Even better, would someone have an image from a 1050 / 1055 hard drive? Any help would be greatly appreciated. Keep up the good work.
Thanx
CraigLeave a comment:
I tried to write to you privately but it gives me this error...
"wav has exceeded their stored private messages quota and cannot accept further messages until they clear some space."Leave a comment:
otherwise does anyone else got one?
thank you so much guysLeave a comment:
hi -
can any one help with a hdd clone of a t1700Leave a comment:
Hello! Sorry for reviving an old thread but i have a Designjet T975 with a hard drive making sounds and giving me 08.11 error. Does anyone have an image for this?
Edit: After hooking up the drive to a pc for cloning attempts its asking for a password as you guys have mentioned already, but where can i find one for that model?Last edited by eberak; 11-16-2023, 07:39 PM.Leave a comment:
update - i have now got a clone for a hp DesignJet t930/t1530- new hdd p/n L2Y21-67004Leave a comment:
hi update i have manage to get a hold of the PUMA_01_03_00.1.fmw file.
if anyone want it to try and install the firmware.
hdd partition list
1st 244.1mb
2nd 11.4gb
3rd 11.4gb
4th 1.9gb
5th 19.1gb
6th 38.1gb
7th 85.8gb
8th 47.7gb
9th 47.7gb
10th 33.4gb
hdd model
ST500LT012-1DG142
500GB SEAGATELeave a comment:
as i have the hdd encryption password so i unlocked the drive and copied it that way.Leave a comment:
Sure will do, i have not tested it yet i didn't plug the machine in.
The machine is now put away in stock -
the hdd copy is done on acronis true image.
for other machines i think they need a certain boot partition then have the firmware on the usb to do a firmware update or see if the eeprom reset can be done.Leave a comment:
Hi - i have managed to copy the hdd for a z5600 that's new. - there's lots of partitions named ex3- 1-3 - ect..
in the folder i found PUMA_01_03_00.1.unsigned.fmw.sig - - this is the signature file .
is this possibly be the first firmware this machine was shipped with
if anyone want me to find certain files or folders on the hdd -Leave a comment:
System Errors - Index by Customer Code0x10504001 DRACO_DATA_MNGMT_NVM_MAIN_CRASH Main NVM failure: not detected, read/write failed or readback error. 06:10 Hard disk Replace. STRING_POWER_OFF Leave a comment:
