HP DesignJet 500 maintenance message
  • HmkPrinterTech
    • Sep 2008
    • 21
    Hey all,
    I have a Designjet 500PS plotter that I have just replaced the maintenance kit on. I have reset all of the eeprom counters, but this message is still showing ont he front panel. Any ideas on how to clear it?
    Thanks! Jeff.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    What is the message? That will help in telling you what your problem is.
    • HmkPrinterTech
      • Sep 2008
      • 21
      "Maintenance Advised" is the message that the plotter is displaying. I already installed the maintenance kit, and reset all of the eeprom counters fromt he service menu, but the message is still there. Any ideas on how to clear it?
      • prntrfxr
        • 1622
        Did you check if the spittoon in the Service Station is full? That can also give you the error message.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Another thing that can cause a non specific message is if the ink tubes are getting stopped up. It comes as a kit and if you can change a belt, then you can change this also. I think the kit is around $400 from HP.
