Reset of Drum on a LJ8000
  • rasman67
    • Jul 2025
    Is there a reset for the laserjet 8000 or does it reset when a new drum is installed
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    New drum, that is where your toner is, so resetting it would just make you run out of toner.
    • prntrfxr
      • 1622
      when you are out of toner and you put in a new one the printer recognizes that its new. There is no need to reset. Only when you replace a fuser or maintenance kit will you need to reset the count.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
