HP 2600 print quality
  • hobbes
    • Mar 2008
    • 11
    Hi,
    can anyone tell me why i am getting prints that are light on one side only.It appears worse on Yellow & Magenta.I have replaced all 4 cartridges but the problem remains.
    Hobbes
  • vale24
    • Sep 2008
    • 62
    hp2600
    hi, how many copies are made with this hp2600. Did you try clear laser glass behind tonercartridge? did you stop paper before fuser and is hte problem in print section or in fuser section? are the new cartridges new or recharged??
    try this and write again!
    success!
    copier and printer service technician
    The perfect gift
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      If the print fades from one side to another, the problem could be in the rack that holds the cartridges. they have to tilt forward to make contact. If the problem is in the rack , it is not worth repair. I have seen many of the old 2500's used as door stops for that very reason.
      • cosmin_mocanu
        • Dec 2008
        • 71
        if the magenta is lighter then yelow your problem is from the laser. as far as y remember the magenta is the first cartridge, from down to up, then is the Y, C, and K. all you need to doo is to disasembli the printer and clean the laser for dust. it is a comon problem for this series (16xx, 26xx, 3500, 3700). if you need the service manual just send me a email adress
        • hobbes
          • Mar 2008
          • 11
          Hi Cosmin,
          thanks for your reply,i will pull out the laser as you sugest and clean it .I have a manual but thanks anyway.
          Regards Hobbes
          • cosmin_mocanu
            • Dec 2008
            • 71
            you welcome, and do not forget to clean alsoo the entire printer for dust and waste toner. And alsoo don't forget to clean the poligonal mirors of the laser, and one more thing, DO NOT USE ALCOOL OR ANI OTHER SOLVENT TO CLEAN YOUR LASER. It will do a lot of damage to the optics in the laser. I personaly use coton buds, the ones used to clen the ears. And take care not to modifi the pozition of ani mirors, or lens.
            Good luck, and let us now if the problem iti is solved.
            • hobbes
              • Mar 2008
              • 11
              Hi Cosmin,
              took all your advice and removed and cleaned mirrors etc.in laser unit.Made a huge difference,print quality as good as new now.Took me about 1.5 hours but i think i could get that down to 45mins now i know what i am doing.
              Regards Hobbes
              • cosmin_mocanu
                • Dec 2008
                • 71
                I'm glad that i could hel you
                • alibaba
                  hi sir ,i was looking for hp service manual could you please sending to me . i am looking you're best rgrd
                  sharifmkp@yahoo.co.in
                  • alibaba
                    • cosmin_mocanu
                      • Dec 2008
                      • 71
                      check your mail
