Hp LJ 4 "57 service" code
  • kmguy31
    • Aug 2008
    • 11
    i have an ancient hp lj 4 that i am working on. It has a "57 service" code. All manuals point to main motor. So i ordered main motor and replaced it. I am still getting the error code!!! Any ideas would be greatly appreciated!!
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Since you looked it up, you also know to check the DC controller. I would look at the cartridge and make sure it is not in a bind causing the motor not to move.
    • prntrfxr
      • 1622
      It's very common for coupler gear on the main drive asm to either seize up or break also possibly bad/broken fuser gears. After gear drive, motor (which you already changed), and lastly DC Controller. Although its possible that the problem is electronic, mechanical failure is more likely.
      RF5-0350 Drive Coupler
      RS5-0237 Gear, 17T/32T (recommend replacing together)
      or replace the entire drive RG5-0457 asm
      RG5-0511 DC Controller
      Hope this helped you.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
