hp pagewide pro 452dw
  • hani002
    • Feb 2020
    • 10
    Hi guys
    i have 2 hp 452dw ,try to remove the main board from printer 1 to printer 2 and this code coming on the display error code 0x8b380001 ec critical_da
    then return back the orginal board to printer 1 and coming the same code.
    any help...
    Re: hp pagewide pro 452dw
    Originally posted by hani002
    Hi guys
    any help...
    YUP just trashed them both,,,
    why did swap boards in the first place?
    frankly these AREN'T worth fixing if having a printbar issue.
    • hani002
      • Feb 2020
      • 10
      i just use one and return it back
      and return back the orginal board to the machine and come the same code
      any solution...
        any solution...
        sure BUY another POS like this and DON'T go switching boards around if you don't know what to do or don't have a damn service manual
        you have bricked both units ! nice going!
        end users should NOT do board swap if you don't know what the fuck you are doing.
          Hi guys
          any help...
          hey BUTTWIPE you don't have a profile... wank off
          • hani002
            • Feb 2020
            • 10
            i dont understand why i fuck this boards
            iam prof electronic technical and know every things about electronics the problem i think its software and need to reset or program the eprom
            not more
            the 2 machines was work before changing the boards and it is my machine
            iam sure there is solution
            • hani002
              • Feb 2020
              • 10
              i was member in this site from 1999 and stop logging for long time and return back today but with new user
              iam waiting the admin to activate my old profile
                not more
                I guess you don't know EVERYTHING
                fuck it I'm done with your know it all attitude..
                such an electronics genius should have to come beg for help then tell the TECH basically " YOU'RE WRONG"
                done dipshit..congrats
                shit you can't even write a proper sentence
                why didn't an ELECTRONICS EXPERT fill out his profile... you sound more like a child. I would block you but since you didn't I can't..
                fucking asswipes waste time with this bullfuckingshit
                • hani002
                  • Feb 2020
                  • 10
                  fuck uuuuuuuuuuuu
                  u think u r right
                  and u cant give any answer
                  fuck uuuuuuuuuuuuuuuuu
                  • copiertec
                    • Jan 2016
                    • 2211
                    Thanks for the Friday night, laugh, Phil!
                      My pleasure brother.. even the electronic's prof that " knows it all " realized he was wrong.. great to know electronics, but if you aren't sure what coding (info) gets stored where ( multiple places on most brands) you and I know how 'quick you can brick' anything. Some things just can't be swapped around.
                      • Zeldaman
                        • Mar 2011
                        • 946
